Ssenuk's avatar
Ssenuk
Follower
Jan 19, 2021
R6300v2
I have a negear r6300 smart wifi router. Approx 6 years old. I am moving to a new residence. I have never updated this firm.  I've never had a problem but shoulbinbuyba new one
1 Reply
  • michaelkenward's avatar
    michaelkenward
    If it does what you want, why spend more money?
    If you do move it, it is a good idea to do a "factory reset". The new network won't be the same. For example, it will have different login details for the Internet and probably a different modem in front. You don't want the router to remember its old settings.
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    While you are at it, it might be a good idea to update the firmware, if only to get any security updates since you bought it.
