Orbi WiFi 7 RBE973
Reply
R6400 blinking white lights
phaave
My lights never go out, power is steady white, Internet is blinking white, 2.4 ghz is blinking white, 5 ghz is blinking white.  The only other two lights that are steady white is wifi on off button and wps button.  Manual says the lights should all be steady white and   should go out after a while, Do I have to do a reset?  I have powered everything down and rebooted 3 times, it is still the same.  I have the latest firmwear version.  Is this a concern??  I don't seem to have any issues connecting to the internet at all.
Thanks
Pat
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: R6400 blinking white lights
Can keep going if your not having any problems.
Might try a reset later on and see.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1998 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
