Orbi WiFi 7 RBE973
Reply
R6400 upgrade
dlchase
Follower
R6400 upgrade
I am planning to upgrade my R6400 router to a newer Netgear router.  Is there a way to copy all of the settings in my old router and upload them to a new Netgear wireless router?  Using Windows 10 64bit
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: R6400 upgrade
No. Backup configuration files from only same model routers can work on other same model routers.
Netgear has set up a community forum specifically for General Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Message 2 of 2
All Replies
Guru
Re: R6400 upgrade
Thank you
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 788 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
