FirestormGTX's avatar
FirestormGTX
R6700 Port Forwarding Not Working
Hello,
I have tried numerous times to get any of my ports to open on my router, and despite many different efforts to get them open, I have had no success.
Things I have tried (In coalition with each other):
-Standard port forwarding
-Restarting router
-Allowed access through firewalls
-Disabled all firewalls
-Enabling a DMZ
I also have run programs that require certain ports to listen while testing them so I know that is also not the issue in this case.  I have tried all standard port checkers as well as grc which turned up with all of my ports being stealthed.  I have also contacted my ISP (Spectrum) and asked if they had anything to do with matter (blocking ports or otherwise), and nothing turned up on their end.  I have run out of ideas on how to fix them problem after scouring forum after forum hoping to find an answer.  I would greatly appreciate any help in the matter of getting my ports to open.
  • FirestormGTX's avatar
    FirestormGTX
    Feb 04, 2018
    I tried redoing the bridging process today, and doing this miraculously fixed my problem.  I guess something went wrong the first time I put the modem-router into bridge mode.
    All is fixed and ports open normally.
  • > I have tried numerous times to get any of my ports to open on my
    > router, [...]
       Why?  Which ports?  What feeds "my router"?  Is it something simple
    (like a modem), or another router?  (Is the WAN/Internet IP address of
    the R6700 a private or public address?  If in doubt, report at least the
    first two octets ("a.b" out of "a.b.c.d").)
    > [...] despite many different efforts to get them open,
       That non-description conveys no useful information about what you
    did, or what happened when you did it.  Standard port-forwarding
    preface: In my experience, people who talk about ports being "open"
    often don't understand the problem.  A port looks "closed" when there's
    no server program (or device) listening at that port.  All the port
    forwarding in the world won't help you if, at the end of the line, no
    one is listening at that port number.
       "success" determined how, exactly?
       Actual port-forwarding rules?  Are you doing something (like, say,
    address reservation) to ensure that then target device has a reliable IP
    address?
    > -Restarting router
       Probably wise.
       Allowed what, exactly, through which firewalls where?
    > -Enabling a DMZ
       Often a last-ditch option.  Less access control that way.
       You lost me.
       Assuming that you're running some server program on some system which
    listens to the ports of interest, can you contact that server from a
    system within the LAN?  If local access fails, then access from the
    outside world hasn't much of a chance.
      FirestormGTX
      Thank you for your response and I will try to address everything to the best of my ability.
      a. I am trying to run game servers from my PC and need the ports open to do so.
      b. I have been trying to open ports 25565 (Minecraft) and also 9000-9004 (Far Cry 2)
      c. My router is connect to a modem-router.  My modem-router is bridged to my router.
      d. I believe it to be private but I am not sure.
      I have been actively running my server programs while testing the ports so it should be listening.
      I have not been able to open any given port.
      address?
      I have just been port forwarding through my router's configuration under the default gateway.  As to this, I do not have an address reservation if you are speaking about a static IP.  This has not been a problem on any of my previous routers.
      I have Norton Security as well as the Windows Defender firewalls on my computer (running the most recent version of Windows 10 at this time).  I have allowed access to the ports through both of these and also entirely stopped their functionality.  Neither of these led to the ports being open.
      I am not sure what you mean entirely here. Sorry for my ignorance.  If you mean can I connect to said server locally (LAN), then yes I am able to.
      • antinode's avatar
        antinode
        Guru
        > to my router.
           What, exactly, is this "a modem-router"?  "bridged" is a specific
        technical term.  Do you mean that the R6700 (WAN/Internet port) is
        connected to this "a modem-router" (LAN port), or that the "a
        modem-router" is in bridge mode, so that it's acting as only a modem, or
        what?
        > [...] (Is the WAN/Internet IP address of the R6700 a private or public
        > address?  If in doubt, report at least the first two octets ("a.b" out
        > of "a.b.c.d").)
           For access from the outside world to work, you'd generally want the
        port forwarding configured on the outer router (closer to the ISP), and
        cascading a second (inner) router would make things more complicated
        ("double NAT").
           To avoid cascading multiple routers, the two usual schemes are:
              1) Configure the modem+router as modem-only (also known as "bridge
                 mode"), and do all the serious work on what had been the inner
                 router (R6700).
              2) Use the modem+router as the main router, and configure the
                 R6700 as a wireless access point.
           Either scheme leaves you with one router and one LAN.  Port
        forwarding is configured on the one (remaining) router, and there's no
        second router to cause trouble.  Which to choose may depend mostly on
        which router has a nicer feature set.
           You lost me.  With two routers, "my router" is a little ambiguous.
        Copy+paste of some actual port-forwarding rules would be clearer than
        any explanation of what you think they're supposed to be doing.
           Port-forwarding rules include a target (server) IP address.  If your
        server is not at that address, then port forwarding is doomed.  The
        server address can be static (assigned in the server's IP
        configuration), or it can be a reserved dynamic (DHCP) address, so that
        the router (DHCP server) always gives it the same address.
        > [...] If you mean can I connect to said server locally (LAN), then yes
        > I am able to.
           Yup.  That sounds good.  The problem may be confined to port
        forwarding.  (And, perhaps, the cascaded routers which complicate port
        forwrding beyond reasonableness.)
