- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 Slow Ethernet Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm using this router in AP mode and the other router is working fine. If I reboot the router is will get over 200 Mbps but within a few minutes it will drop down to 20-50 Mbps - both test in a wired connection.
V1.0.4.120_10.0.91 |
Any suggestions on what to try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 Slow Ethernet Speed
Have you tried a factory reset?
Did it just start or has it been going on for a while? (if so, how long)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I did a reset and it didn't help. About 10 minutes later it went from 200+ down to 20-50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does it stay constant in router mode? maybe the primary router you're using has a qos thats slowing it down
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disabled AP mode off it didn't help. The QoS on the other router is off and has never been on. Any other ideas? Very perplexing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
*AX1800 is a speed not a model*
If you swap the tplink and the r6700 with the r6700 in router mode, is it still slow?
