Orbi WiFi 7 RBE973
Reply
R6700v3 Firmware Version 1.0.4.120
Eko6
Actualize mi router de forma manual con la versión R6700v3 Firmware Version 1.0.4.120
y al intentar acceder a routerlogin.net
192.168.1.1, 192.168.1.0 router login.com
De las diferentes formas que recomienda y no puedo acceder al home para terminar la configuración.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: R6700v3 Firmware Version 1.0.4.120
Press the back reset button for 10 seconds then release. The try to access the routers web page at 192.168.1.1.
I would turn off any broswser security add-ons while you do this.
Message 4 of 6
All Replies
Guru
In inglese per favore
Message 2 of 6
Eko6
Update my router manually with R6700v3 Firmware Version 1.0.4.120
and when trying to access routerlogin.net
In the different ways it recommends and I can't access home to finish the configuration.
Message 3 of 6
Guru
Message 4 of 6
Eko6
Tanks world good.
Reset 10 seconds and disable my firewall and works tank you
Message 5 of 6
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1961 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
