Orbi WiFi 7 RBE973
Reply
R6700v3 -- older firmware
seifrjd
I have an R6700v3 router, and I am experiencing SLOW download speeds.  I read multiple threads that address slow downloads through the ISP after applying firmware version V1.0.4.128_10.0.104.   The solution seems to be to roll back to the prior firmware version.
Where can I find prior firmware versions, in particular the one most recent BEFORE the current one?
Thanks for any help.
Message 1 of 4
Accepted Solutions
seifrjd
Re: R6700v3 -- older firmware
I found my own answer.   Sorry for taking your time and space.
For anyone else with the same questions, here's the link... prior versions are near the bottom right of the page.
https://www.netgear.com/support/product/R6700v3#download
Message 2 of 4
All Replies
seifrjd
Message 2 of 4
Guru
I also saw posts where some users contacted NG support and was given a non published beta that seemed to solve problems as well. Might make contact with NG support and ask about this as well.
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 4
seifrjd
Thanks for the suggestion.  I'm beyond my support period, so not sure if they'll talk to me.  PS - also sending you a PM re: the beta firmware for RAX120v2.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1198 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
