Orbi WiFi 7 RBE973
Reply
R6700v3 suddenly not found in wifi list
Trv89
Follower
Hi all, so like the description says. Everything was going fine and then all connections just dropped.
Did a reset of modem and router. Nothing.
Modem shows service and no reports of outages.
Router reset and now only has two left lights on front on. Normally has 5ghz and wifi signal light on as well, but not anymore.
Is this thing toast? Or is something else going on?
Thanks for input!
Message 1 of 2
Kitsap
Master
Re: R6700v3 suddenly not found in wifi list
Thanks for input!
You have managed to turn off the Wi-Fi radios.  The second indicator in from the right side is a combination indicator/switch.  Push and hold the LED for a couple of seconds, then release.  That should turn on the Wi-Fi radios.
The manual Wi-Fi radio on/off switch over-rides both the reset operation and power on/off sequence..
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 820 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
