PhyllisJ's avatar
PhyllisJ
Follower
Jul 25, 2022
R6700v3
I have set up the router. This computer and my phone are connected but not the TV or Alexa.
1 Reply
  • plemans's avatar
    Are you needing help with something?
    You weren't very specific.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
