Hanksplace's avatar
Hanksplace
Follower
Aug 01, 2023
R6850
Setting up router
Don't know what to do at use wifi add network
What do ido now
  • what is your problem? "Don't know what to do" is not a problem description!
    Which firmware version do you run and what's the modem/ONT in front of the R6850?
  • michaelkenward's avatar
    michaelkenward
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Begin with the Quick Start/Installation Guide.
