Orbi WiFi 7 RBE973
Reply
R6900P ROUTER: I keep getting firmware upgrade notices, but then Nighthawk app says there are none.
txakura
For the second or third time in the past coiuple of years, I received an email purportedly from Netgear telling me there was a "security" firmware update for my router.  When I went to the Nighthawk app on my tablet, however, I was told there were no updates.  Was this a "phisihing" email, or don't I need the update - or does the Nighthawk app have a problem?
Message 1 of 2
Guru
Re: R6900P ROUTER: I keep getting firmware upgrade notices, but then Nighthawk app says there are n
Which firmware version are you on?
You can see the versions on the support site to compare.
https://www.netgear.com/support/product/R6900P.aspx
the emails sent out aren't always the most accurate.
Message 2 of 2
Discussion stats
  • 1 reply
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
