Orbi WiFi 7 RBE973
Reply
R6900v2
Risinger
Tutor
R6900v2
I am a trucker and have bought this model to enable operation of my on board camera system for security reasons. However I also need internet and would like to find out if I can connect my hotspot to this router to achieve this. Any help would be greatly appreciated.
Message 1 of 8
Accepted Solutions
Risinger
Tutor
Re: R6900v2
Thank you. I will try that out. Seems it may just work. Will keep you posted.
Message 6 of 8
All Replies
Guru
Re: R6900v2
The R series router requires a ethernet WAN connection from a Modem, DSL, ONT or Cable modem that provides internet services to the router. You'll need to ask the mfr of your hot spot about support for external wifi routers.
Message 2 of 8
Guru
Re: R6900v2
What hotspot do you have? That's the key.
Message 3 of 8
Risinger
Tutor
Re: R6900v2
I have an inseego mifi 2000 mobile hotspot that is capable of tethering by connecting via usb or using radio and logging onto the hotspot. Details are at inseego.com. Thank you for your help.
Message 4 of 8
Guru
Re: R6900v2
The R6900 doesn't have the option to take wan input from a usb teether.
You could always check to see if that hotspot could use a usb---ethernet adapter.
I've actually seen someone use a powered hub so it powered the hot spot and connect the usb--ethernet adapter to that.
then connect the router to that. You'd want the r6900 in ap mode though.
Can't 100% say it'd work because I don't have that hotspot to test and I doubt the documentation would go over that scenario.
Message 5 of 8
Risinger
Tutor
Re: R6900v2
Message 6 of 8
Risinger
Tutor
Re: R6900v2
Perfect. The Ethernet adaptor to usbc adaptor worked . Thank you
Message 7 of 8
Guru
Re: R6900v2
Glad it worked for you!
I'd mark it solved so others aren't still trying to fix it 🙂
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3379 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
