Orbi WiFi 7 RBE973
Reply
R7000 (AC1900) as Extender/Repeater/AP?
93dx
Hi All,
I'm hoping someone can help me out..
My main router is a Netgear RAX80 (positioned on the main floor of 2-storey home) and it seems as though I have a weak wifi signal upstaris in my home..
So...I came up with this bright idea to why not use my old R7000 as a (I'm not sure which and hope one of you will tell me) Repeater or Extender or an AP?
Can you make a recomendation as to which setup would be best for my situtation?
And if possible provide a link with detailed instructions re:setup process?
*I should mention: Hard wiring between the routers is not possible as they are on seperate floors)*
Thanks in advance!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Guru
Re: R7000 (AC1900) as Extender/Repeater/AP?
Access point mode would need them hardwired together somehow.
so you'd probably want to try extender mode. The R7000 will still need a half decent signal to pickup to rebroadcast.
There's instructions on how to setup extender mode here:
https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router
Message 2 of 3
93dx
Thank You I appreciate you taking the time to reply to my question..I will give your recommendationa try.
Thanks again!
Message 3 of 3
Discussion stats
  • 2 replies
  • 839 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
