Orbi WiFi 7 RBE973
Reply
R7000 Can not download firmware 1.0.5.48
iochoa2
I tried to download the firmware from the support site, but I got a trunkate file, with just 3 MB size, I could download the previous firmware, but the in the new release I got this problem, anyone that could help me.
Thanks.
Message 1 of 10
Accepted Solutions
iochoa2
Re: R7000 Can not download firmware 1.0.5.48
Thanks, It was magic, I tried that several times, this time works!!
Thanks.
Message 3 of 10
All Replies
Babylon5
NETGEAR Employee Retired
Following the ‘Download’ link at the top of this page I was able to download the firmware you refer to, have you tried using a different computer / smartphone etc.?
Message 2 of 10
iochoa2
Thanks.
Message 3 of 10
DanT2590
Tutor
I've tried for a week and can't get 1.0.5.48_1.1.79 to download.
I also tried downloading the zip file, but when I went to unzip, it says not a valid format.
I would really like to upgrade since my version is getting pretty old since I flashed the memory.
What else can I try????
Message 4 of 10
Babylon5
Have you tried downloading using other PCs?
I'm actually having trouble accessing the 'Downloads' page right now, I'm at work but even so can normally access it here, so I'm guessing that there may be server-side issues. If this is still the case at the end of today I will contact Netgear (or another moderator might check in the mean-time).
Message 5 of 10
DanT2590
Tutor
Yes, I've tried using 3 computers here in the house. All of them do the same thing. The zip file won't unzip and says its corrupt!
Message 6 of 10
iochoa2
Hi.
What work for me is in the download page when the popup said to register again, I enter ALL THE DATA with the Router SN and click register and download.
That was the only valid way to get a valid file.
Hope this work for you.
Message 7 of 10
Babylon5
It seems the Download server is down, so I suggest that you wait until the server is available again and repeat the download.
Message 8 of 10
DanT2590
Tutor
I'm already registered and logged into my account
Message 9 of 10
Babylon5
I was just able to access the download server (the ‘Downloads’ button above) and I downloaded the R7000 firmware. The Zip file was fine, and I could see the firmware and release notes inside. Registering a device is optional, the downloads are still available without registering.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 5229 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
