- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Internet Speed not the same as Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Read through a few threads here about a similar issue, some are a little out-dated regarding the "preferred firmware" people have tested and gotten the best results with.
ISP: Spectrum - 1Gig speed package
I had Spectrum out earlier this week and they found a few issues with the modems line. That was all corrected and retested and showed improvement. From the modem directly, I pull down ~950Mbps and upload ~55Mbps
Once plugged into the LAN port of the R7000 I never get more than ~250Mbps down and ~40Mbps up
- The desktop has a gig network card and Windows recognized that and the gig speed is negotiated in the adapter status
- Last month, my hard wired desktop was pulling the proper speeds around 900Mbps down and 50Mbps up without issue
I'm just not sure what would have changed or caused an issue
I did upgrade the router firmware to the latest last week hoping that would help, but it did not.
Is there a firmware version I can roll back to that's better?
Thanks everyone!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset the router.
during the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls disabled.
that router is 9 years old and needed cut through forwarding (ctf) to hit gigabit speeds. those services disable it.
so try that and then test the speeds.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Internet Speed not the same as Modem
How are you speed testing? Wired or wireless speed testing?
What I see with mine:
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router firmware version: 1.0.11.134_10.2.119
ISP Modem: Looks to be Spectrum branded - EU2251 DOCSIS 3.1 eMTA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, make sure ipv6 is enabled. I've also seen that cause a few slow downs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should the factory reset be done through the UI portal or the paperclip button on the back?
Which is preferred? Assuming both accomplish the same task, but I never know with NetGear sometimes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Either should work. Its just to force the router to reset the CTF. Sometimes even disabling those services doesn't re-enable it and thats where the reset comes in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Beautiful!
Factory reset is complete
Set the router back up with my usual settings
Made sure Traffic Meter, QoS, and Parental Controls were off
Now pulling down over 900Mbps and 50Mbps up over the wire
Thank you so much!
Edit: Also enabled IPv6 to Auto-Detect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it took care of the issue!
A backup is a good idea now that you have it running the way you want 🙂
