AchiliesFury
May 14, 2021Follower
R7000 Nighthawk OpenVPN Enter Management Password:
Hey guys,
Trying to set up a VPN through the router. My issue is when I connect I get a Enter Management Password: in the log. I do not know what to do. Also how do I get that other error resolved? Any help?
Config File:
client dev tap proto udp sndbuf 393216 rcvbuf 393216 push "sndbuf 393216" push "rcvbuf 393216" dev-node NETGEAR-VPN remote ****.mynetgear.com 12974 resolv-retry infinite nobind persist-key persist-tun ca ca.crt cert client.crt key client.key cipher AES-128-CBC comp-lzo verb 0
Log:
Enter Management Password: Thu May 13 19:52:51 2021 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
1 Reply
AchiliesFury wrote:
Any help?
Tried this?
Search - NETGEAR Communities – OpenVPN
Plenty of conversations about OpenVPN and various error messages.
I assume that this is the VPN you are playing with. You message doesn't specify.
