- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Wrong Date/Time after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Wrong Date/Time after firmware update
Thanks oseiasslompo!
I've now downloaded the beta firmware mentioned in the later reply from ElaineM and installed that. No sign of the correct date so far but I'll see if it updates over the next day or so.
If it doesn't work I have a copy of later firmware than the one you suggested, R7000-V1.0.4.30_1.1.67.chk from last May, which worked fine, so will go through the same process again and see if that fixes it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks ElaineM.
I've now installed that beta firmware. It's currently showing 1st Jan 2005 again but there's nothing in the logs about time check so I'll give it a day or so and see if it picks up the correct date. If not, I have an older version of the firmware from a year ago, which worked fine then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't forget to reset after loading the new beta firmware.
I am currently using the beta and it's showing the correct date on mine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same poblem and reset dosen't help. It started when I switched from Comcast to ATT gigiaPower. I have R7000 and R8000 and same issue on both and posted in troubleshooting forum and no fix yet. There is no manaul way to set the time in router. After reboot Router time goes back to Jan 1, 2015 for R8000. This makes router bandwith meter and also security / schedule to block servies useless. Router use to work fine behind comcast modem. If I switch router to AP mode from route moder it sync time fine. Switch back to router mode no time sync. Firwall is off on Uverse modem so it is not that. This is in logs on startup. Looks like a delay of 1 second to connect to internet. If you get [Internet disconnected] Thursday, Jan 01,2015 00:00:21 that means router will never update time after that.
[Internet connected] IP address: xx.xxx.xxx.xxx, Thursday, Jan 01,2015 00:00:22
[Initialized, firmware version: V1.0.3.4_1.1.2] Thursday, Jan 01,2015 00:00:18
[DHCP IP: (192.168.1.3)] to MAC address XX:XX:XX:FDC:XX, Thursday, Jan 01,2015 00:00:16
On R7000 I am running V1.0.6.28_1.1.83
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried both now but still get - Current Time: Thursday, 01 Jan 2015 00:01:05
and now am on V1.0.5.62_1.1.87
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried all the options given on different forums but no luck. Netgear support gave me beta V1.0.5.49_20151208_timesync firmware which fixed the issue.
[Time synchronized with NTP server] Thursday, May 05,2016 15:25:28
[Internet connected] IP address: xx.xx.xx.xx, Thursday, May 05,2016 15:25:28
[Internet disconnected] Thursday, May 05,2016 15:25:27
[Initialized, firmware version: V1.0.5.49v1.7] Thursday, May 05,2016 15:25:20
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reset my router via the web interface but should I do it instead manually via the little hole on the back? I restored settings from the back up I made. Would it be better if I make a note of everything instead and re-enter them all? (Didn't do it that way as with all the things on our home netwrok having reserved addresses it would have been rather time-consuming.)
My R7000 is connected to the internet via a BT Openreach fibre broadband modem, supplied by my ISP (the free router they sent to plug into it wasn't very good so I bought myself the R7000). I'm pretty sure it was getting the time OK till the latest firmware update v1.0.6 etc late last year.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can I get that firmware to try???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes! I would like to try the timesync version of the firmware too. Sounds like it would fix the issue!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Open support ticket and they will give you the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did open a ticket but because I've had my R7000 for more than the 90 days of free support (bought it Summer 2014), they closed it. I can't go for the telephone support option as I'm in the UK and it would be too costly to ring the USA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Further to my previous reply, I've found the UK support number but see how much it costs per incident. As this problem was caused by me updating my router via its web interface, where it was telling me that new firmware was available (which, incidentally, isn't now on the download page for the R7000) I don't see why I should pay! I'll just have to wait till the release version is available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@madmoggies & @AkivaM Let me forward you guys to one of our support team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would appreciate being forwarded to the support team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Support team sent me beta
Firmware Version V1.0.5.49_20151231_ntp |
And that fixed it for me
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for that, Elaine.
I was out most of yesterday and earlier today, so have only just got down to catching up. Have agreed to the beta software and am now waiting for it.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
..... and I've got my time and date back successfully now too!
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I,m having problems with NTP not working on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have the same problem, as below, just started
R7000 Nighthawk AC1900
current firmware V1.0.4.30_1.1.67
2016-05-05 12:29 PM
How can I obtain this firmware update?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I am having the same problem with the time and date not updating. Is it possible to post the beta NTP firmware file?
Thanks,
Barry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Please PM me your contact information if you have issue with time and date.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
