- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 and latest beta 1.0.6.40_1.1.90 small cosmetic bug
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I updated recently to 1.06.40. For now, it seems much more stable than previous 1.0.5 and 1.0.6.28 versions
I still have it to run for a few days without reboot and under havy p2p load to see if it stalls like previous versions
However, speed seems same in NAS Tester tool and over WAN for my 250 mbps connection
One small thing: Arlo option is only shown under Basic setup, not under Advanced. I missed it because I never use teh Basic tab!
Also, if I disable the Arlo, wifi connection related to the Arlo stays enabled until next rooter reboot
Other than broken ipv6, I see no other issues with this firmware. I will give feedback in a few days for long run stability under heavy p2p load
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chopin70,
Please check this official firmware for stability.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 and latest beta 1.0.6.40_1.1.90 small cosmetic bug
Hi Chopin70,
Are you using the R7000 for Arlo purposes? If not, you may try using the beta firmware v1.0.5.62.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/m-p/1078114#M31145.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use it as a general purpose, no need to Arlo services. However, I upgraded to beta because I need the Android OpenVPN support not present in current stable 1.0.4.30 version
I had tested 1.0.5.48 and 1.0.6.28 in the past and they were very unstable in the long run with a heavy load
Is 1.0.5.40 just an Arlo stripped 1.0.6.40 firmware that will provide same stability?
Thanks again for your support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also if you are running R7000 as Access Point 1.0.6.40 is fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chopin70,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks, I will upgrade to latest official stable then
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi chopin70,
Provide us feedback after updating to the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will do for sure
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest 1.0.5.64 seems very stable and fast as 1.0.4.30, OpenVPN for Androdi works perfectly too
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chopin70,
Thank you for the feedback. You may close this post but tagging the appropriate post as "Accepted Solution".
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
