- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 - configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to check if there is a setting on my router called SIP-ALG and if so disable it but I am unable to find how to check the configuration.
I've tried going to routerlogin.net but it doesnt accept the username and password (which are the defaults) and it wont accept my serial number to recover the password.
I'm unable to fnd anywhere on the nighthawk app to find the configuration either.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
here's how to disable sip alg.
If your not able to get in either because of wrong password, unknown password, or password recover wasn't setup then you'd need to factory reset to get back in. push and hold reset for 7-15 seconds while powered on. that'll reset everything back to stock.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
