Orbi WiFi 7 RBE973
Reply
R7000 default gateway missing
harrma
Whenever I try to use this router I get ip adress incorectly cinfigerd and when I do ip config /all the defalt gateway is missing and factory reset didn't work nor did these:
https://validedge.com/ethernet-doesnt-have-valid-ip-configuration/
https://www.techjunkie.com/ethernet-doesnt-t-have-a-valid-ip-configuration/
https://forums.tomshardware.com/threads/ethernet-doesnt-have-a-valid-ip-configuration.1979328/
The prevous owner said it stopped working when he updated the firmware, but I can't figure out how to fix it and I cant axsess the router page at its IP adress. Please help, thank you. (on windows 10)
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Guru
Re: R7000 default gateway missing
maybe the prior users bricked it.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 5
harrma
the first one said it falled to connect to target and the seccound says (firmware) file not recognized
Message 3 of 5
Guru
tftp can take a few tries as its sensitive to timings.
Make sure to watch the video.
Also, ensure you're using the correct firmware
Message 4 of 5
antinode
Guru
   Firmware version?  Connected to what?
> [...] I cant axsess the router page at its IP adress. [...]
   Which IP address?
   "can[']t" is not a useful problem description.  It does not say
what you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   Speaking of "LED indicators", what are they doing?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions and "Troubleshoot".  Further reading might not hurt,
either.
> the first one said it falled to connect to target [...]
   None of that is a useful problem description.  See "not a useful
problem description [...], above.
   The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error.  By itself,
saying that you tried it doesn't say much.  See "As usual, [...]",
above.  Especially when using a command-line program, copy+paste is your
friend.
> [...] and the seccound says (firmware) file not recognized
   Which "(firmware) file"?  Has it a name?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 714 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
