- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 firmware version 1.0.5.64_1.1.88 released today
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Firmware Version | 1.0.5.64_1.1.88 |
Release Notes | |
1. [New Feature] Supports Smart Connect. | |
2. [New Feature] Supports the Kwilt app, which can be used to view photos stored on the R7000. | |
3. [New Feature] Supports NETGEAR Downloader (Beta). | |
4. [New Feature] Supports VPN service support for iOS and Android mobile clients. | |
5. [New Feature] Sends log reports via SSL email. | |
6. [New Feature] Supports IGMP proxy for British Telecom. | |
7. [New Feature] Supports Transmit Power Control. | |
8. [Enhancement] Improves port forwarding by allowing fixed and range ports to be added to one rule. | |
9. [Enhancement] Improves the QoS GUI. | |
10. [Enhancement] Supports IP-MAC binding for the PR region. | |
11. [Enhancement] Supports Super WiFi for the PR region. | |
12. [Enhancement] Supports DNS 3322 for the PR region. | |
13. [Enhancement] Supports Russian WAN installation and IPTV port support | |
14. [Bug Fix] ReadyShare Printer Vulnerability issue. | |
15. [Bug Fix] Fix Web GUI missing genie app download page when accessing from Windows 10 Edge browser. | |
16. [Bug Fix] iTunes 12.1 support. |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 firmware version 1.0.5.64_1.1.88 released today
Before I load this up, does it fix the 2.4Ghz to be working again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if mine is working without any issues and I see nothing I need here.. I'm not going to upgrade?
Are there fixes that may be important but are not listed here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RMiNJ Better check out the Bugs Fixes under the Release Notes.
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am currently on a previous release number V1.0.6.28_1.1.83 Can I update and is it an upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks good so far.
Seeing signal strength improvement on the 2.4Ghz band.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@chadashcroft Just a reminder, this release still does not include Arlo Support. So, if you're using that feature you will not see that on this firmware release.
However, feel free to update your firmware using the Update button on the router admin page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks...can you paraphrase the best firmware update process for me? As I understand it its something like;
a.) update using the update button or manual update ..
b.) set new firmware to factory defaults
c.) recycle router again
d.) key in all my settings again..
e.) reset again..
Thanks a bunch
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, about #7. [New Feature] Supports Transmit Power Control.
Can I configure my router to run over 100%?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re : R7000 firmware version 1.0.5.64_1.1.88 released today
GA
i wanted test bittorrent download, but nothing beguin to download..i wrote link in case and ADD..and after nothing..where i must click to beguin download ? no help in tip.
Thank for info
Eric
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, only up to 100%, from 25% up in 25% increments.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Eric738 wrote:GA
Thank for info
Eric
@Eric738, not sure what you are asking for, but I don't think it belongs in the thread subject. Start a NEW Subject please that defines the problem and post that. That way someone who knows about Bittorrent should answer (or ask in a Bittorrent forum?).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm only modestly technically skilled, so I'd just like to ask for a little clarificationo on the firware update process. Netgear's update instructions (http://kb.netgear.com/app/answers/detail/a_id/30695) say nothing about a need to reset to factory defaults after the upgrade, thus requiring the user to key in all the settings again.
Can you comment on the on yours (and others) suggestion to reset the router and re-enter settings, in light of Netgear's not mentioning the need to do this? It's not the end of the world to have to renter the settings, but it's not pleasant either.
Thanks,
Anton
- Mark as New
- Bookmark
- Subscribe
- Permalink
Generally speaking, it is the best thing to do. Especially true it seems when going from a beta that has a higher number than the official release or to a lower release beta.
I've been doing that for years it seems. Not doing so has caused problems that I discover later.
If going up in official release to a newer one I've not done the reset/reload, but if I encounter problems I do do that. I never use a prior versions saved settings. I usually don't even save the settings as it isn't worth it to me.
Others may have different opinions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok i post in new thread.
Eric
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I cannot find this setting: [New Feature] Supports Transmit Power Control.
Does someone know where the Transmit Power Control setting can be found?
Thanks,
Anton
- Mark as New
- Bookmark
- Subscribe
- Permalink
False alarm, found it.
Anton
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7000 NETGEAR ROUTER After updating (downgrading) to version 1.0.5.64_1.1.88 Going into -- Advanced -- Setup -- Qos Setup -- Downstream Qos -- Enable Downstream QoS (Improved Video Streaming) causes Netgear Genie to CRASH (completely non respo...The server closed the connection without sending any data. No amount of pausing to wait for recovery suffices, to get 'Netgear Geinie' functioning again requires POWER CYCLING.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thankfully, my installation has not exhibited this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/app/answers/detail/a_id/30695
'(Bets)' should be '(Beta)' in the following sentence:
Supports NETGEAR Downloader (Beta). NETGEAR Downloader (Bets) allows you to directly download files from the Internet to a USB drive connected to the router. To set up your NETGEAR router, see How to configure the NETGEAR Downloader feature
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
There is something I don't get. How's this a new firmware? 1.0.5.64_1.1.88 ?? When the "actual" is V1.0.6.26_1.1.83
Can't be a new one...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The later versions were pulled. The newer versions are a step backwards in terms of function having dropped support for Arlo for the moment. I guess Netgear thought that was reason enough to swap to a lower version number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That IS the newest OFFICIAL Firmware release. The beta you referenced was pulled and newer ones with V1.0.5.60 and .62 were released WITHOUT Arlo support and provided for improve stability which is the reason OLD Beta's were recalled and deleted from distribution.
If you require Arlo support, call NG for firmware that supports it it seems.
