Reply
R7000 firmware version 1.0.5.64_1.1.88 released today
AntonK_58
Tutor
Re: R7000 firmware version 1.0.5.64_1.1.88 released today
They've now bumped the version number up to R7000 Firmware Version 1.0.5.70, with what appear to be some minor changes.
Anton
Message 76 of 83
bigdps
Well imagine that. After a week of nothing but problems, this new firmware fixed my problems. Thanks to all of those who have helped me try to find a solution to my woes. Unfortunately, I can't say the same towards the Netgear people as throughout my ordeal, not ONCE did I hear from them. Shady customer service at its best.
So this is what I think: Netgear does have a good product when it works but the same can't be said about their relation with us, the customers. Very sad.
Message 77 of 83
rve52001
Does 1.0.5.70 fix the GUI not changing?  I had the same problems as some where when I downgraded from 1.0.6.40 to 1.0.5.64 the GUI stayed at 1.0.6.40-2.1.38.1.  The funny thing is I was having strang wireless issues untill I put 1.0.6.40 back on.  So was wondering if anyone downgraded to 1.0.5.70 without any issues?  And yes I reset my modem each time and manually changed settings each time I allways update my modem.
Message 78 of 83
bigdps
I don't know about your problems but for me, going to 1.0.5.70 fixed my nightmares.
Message 79 of 83
rve52001
I was having speed issues on my wireless 2.5Ghz.  My speeds were all over the place.  I think it had to do with trying to downgrade firmware and the GUI staying the same version no matter which firmware I tried.
Message 80 of 83
bigdps
Have you tried the 1.0.5.70 on your router? That's the one that worked for me.
Message 81 of 83
rve52001
Not yet, but before I did, I was was inquiring to see if it fixed the GUI not changing before I did?   I didn't want to go through all the trouble with resetting and reconfiguring everything if it didn't work for others.  I had a suspicion it had to do with the GUI staying the same when downgrading to 1.0.5.64.
Message 82 of 83
bigdps
Well for me, it did a whole lot of difference. One thing I did and it usually isn't recommended was I saved the configuration before I updated the firmware. I know we are supposed to start from scratch but in my case, I had done it way too many times. Long story short, after saving the cfg file and updating the firmware, yes it cured all my problems. Yes the GUI is updated to the latest firmware but all is good. I don't careless if there is a newer update as I won't install it. Working on a network probleem for a week is counter productive. Right now it is solid again and I want it to stay like that.
Hope you find the same success as I did.
Message 83 of 83
Top Contributors
Discussion stats
Announcements
Orbi WiFi 6E
