- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 hook this up while at an area with no signal for phones and no cpu
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried hooking this up in an area that i have spectrum internet but have no phone signal and no cpu. How are you supposed to do that since this should be plug and play when it's obviously not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R70000 hook this up while at an area with no signal for phones and no cpu
Not sure what actual issue your having.
There's always some install process but you haven't said whats failing, whats not working, or anything to go on other than you have an R7000 and no cell service.
(fyi, a router isn't going to provide you cell service)
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem I am having is i can't set it up because my phone says no internet connection. And since i don't get cel signal i can't use the app because of no signal. Though my phone finds the router but no internet connection so can't use app or anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can set it up using a web browser either on your phone or on a pc.
You don't need to set it up using the app
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cant pull up web browser with no signal, wifi or otherwise, on phone,smart tv, or cpu. can't bring up google.com and Can't go to google play store because "No Signal"
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't need the internet to go through the setup process.
You connect to the wifi or using the ethernet and go to routerlogin . com or its ip address. Default is 192.168.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
That note or explanation should have been in the instruction choices.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Page 22 of the UM has web page access and setup information:
https://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
