- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 in AP mode Shows Wired Connections Not Connected To It
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure if this is right or wrong. I have my R7000 set-up in AP mode and connected to my 28 port Cisco switch on port 25, the switch is then Trunked to my Uverse gateway for internet access on port 27. Since the R7000 is downstream of the switch and Gateway with no direct connections on any of it's 4 ports I didnt expect to see any wired devices show up on it's connected devices page. However I am seeing all wired devices on my network being reported as "connected" to the R7000 when viewing the R7000 connected devices page. Is this normal, or do I need to change my switch configuration in some way? (It is a managed SG300-28, so I can make further modifications if required.)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Gandolph wrote:Not sure if this is right or wrong. I have my R7000 set-up in AP mode and connected to my 28 port Cisco switch on port 25, the switch is then Trunked to my Uverse gateway for internet access on port 27. Since the R7000 is downstream of the switch and Gateway with no direct connections on any of it's 4 ports I didnt expect to see any wired devices show up on it's connected devices page. However I am seeing all wired devices on my network being reported as "connected" to the R7000 when viewing the R7000 connected devices page. Is this normal, or do I need to change my switch configuration in some way? (It is a managed SG300-28, so I can make further modifications if required.)
It's Layer2 ARP. I suspect, your network, like mine, is one subnet (broadcast / collision domain)? As I see all my devices, on my AP's also. R7000's running different fw, but in AP mode. If you could see that ARP cache, on your AP, you would see it refelcts the AP's attached devices list.
I suspect @Wolf_666 may be running a seperate VLAN (subnet) for his AP, and, or, clients, and would only see those devices that are in that broadcast domain.
ARP: http://www.erg.abdn.ac.uk/users/gorry/course/inet-pages/arp.html
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 in AP mode Shows Wired Connections Not Connected To It
I have the same configuration, R7000 as AP, connected to a Switch then to pfSense router/firewall and I see only the connected clients in R7000's GUI, I mean the only directly connected to R7000. Your scenario is strange to me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every Netgear router I ever used when in AP Mode showed every device Attached to the Network as wired if Not attached directly via Wireless to AP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have decided to use VLAN's on my network to segregate the wireless and wired network. Thanks for the information to all that responded.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
