Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 looses access and password weekly
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-06
05:42 AM
2021-02-06
05:42 AM
First started off about every other month I would loos internet access but I figured it was probably my ISP changing IP address, then recently I have been having to restart my router weekly for the past couple weeks because I will all the sudden loose internet access then several minutes later I will loose WiFi connection and can’t even access with a hardwired computer. Also when this happens and I try to re access my network it says my WiFi password is incorrect. But if I re boot my router it goes back to normal like nothing ever happened.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-06
07:21 AM
2021-02-06
07:21 AM
Re: R7000 looses access and password weekly
What modem/gateway is the R7000 connected to?
What firmware is on the R7000? It hasn't been known for the best firmwares.
The agreed upon stable version is the 1.0.9.42
But some have had luck with the newest 1.0.11.116
Any changes in frimware to the R7000 should be done over a hardwired connection. I also recommend a factory reset and a clean install for best results.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-06
07:48 AM
2021-02-06
07:48 AM
The version is currently on 1.0.9.88
I have tried to update and said it’s up to date. I will try a clean wipe and go from there
Where do I download the old version of firmware from?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-06
07:55 AM
2021-02-06
07:55 AM
You can get it from here:
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
I'd try manually updating first to the newer version. Some have had great luck with it
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-06
08:09 AM
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
