Orbi WiFi 7 RBE973
Reply
R7000 nighthawk.
revat6
Follower
R7000 nighthawk.
Need help with my settings. I want to get lag free gaming. My speeds are 1.2G from Xfinity but with the nighthawk I’m only getting 200-300 or way less l. Mainly when qos is active
Message 1 of 2
microchip8
Master
Re: R7000 nighthawk.
Disable QoS. It's only beneficial at low speeds. Also, your router can handle a max of 1 Gbps, less than you get from your ISP.
What is the firmware version?
Do you have a modem-only or a modem+router from your ISP? If the latter, you're most likely in a double NAT situation that can be slowing you down
Message 2 of 2
Discussion stats
  • 1 reply
  • 570 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
