Orbi WiFi 7 RBE973
Reply
R7000 router very slow
Denbeau
I've had this router for a couple years but never checked my speeds till lately. Comcast wanted to up gread me to 75mpbs. They said I was paying for 25. I checked and I am only getting 9.5 mpbs download and 2.5 upload, (this is with a wired computer). I had them send a service person who found I was getting 30 out of the modem, but 9.5 out of router, which he doesnt fix. So I upgraded to laterst firmware, reset, still the 9.5.  Did some reading here and saw some had luck with downgrading, so I installed  V1.0.4.30_1.1.67 , same result. I moved my computer cable to a new port, same results. I'm getting steady 9.5 no matter what I tried.
Any suggestions?
thanks
Denbeau
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 10
Accepted Solutions
Denbeau
Re: R7000 router very slow
I gave up...purchased a Linksys. Speed up, strong wifi signal....  wife happy!
Message 10 of 10
All Replies
IrvSp
Master
I WMM on? Any Wireless devices being used?
Have you tried a RESET of the router using the back recessed button? Do not re-enter any settings and test speed.
One thing to try, replicate your PC's MAC address to be the Router's (ADVANCED=>INTERNET SETUP=>ROUTER MAC ADDRESS) and see if the speed is correct after re-booting the router.
Message 2 of 10
Denbeau
II have the 3 wired devices and couple of wifi. The my laptop connected by wifi is roughly the same speed. And yes I re-set using the little button on back.  I re-set after every firmware change.
I'll try your suggestion,with Mac address tonight, Thanks
Message 3 of 10
Denbeau
"Do not re-enter any settings and test speed."
I'm not sure what you ment by this?
Message 4 of 10
IrvSp
Master
When you use the RESET button all settings are RESET. If you load a saved set or re-enter them it is possible that one is causing the problem. A 'factory reset' condition will allow a wired PC to test the speed in the default router setting state.
Message 5 of 10
Denbeau
Ok I see... I didn't change any setting from factory when I set it up. And havent change any settings for now.
Message 6 of 10
Retired_Member
Not applicable
Push reset until Power Led flashes
Message 7 of 10
Denbeau
Ok
Message 8 of 10
Denbeau
I reset and couldnt get back to even slow speeds... no internet at all. Rebooted everything in order....getting yellow!
I give up... I will be buying a new router today... not  a Netgear one.
Message 9 of 10
Denbeau
Message 10 of 10
Discussion stats
  • 9 replies
  • 3809 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
