- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 wifi trouble
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a weird wifi issue with my Nighthawk. I have some devices (printer, etc) which I can only get to connect to my guest wifi. I enabled both 2.5GHz and 5GHz in different configurations, but I seem to be unable to replicate the one of the guest wifi. I have of course triplechecked the password. Any idea of what could be wrong?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are the Wi-Fi settings (SSID broadcast, security mode, speed mode, channel) on the router?
Can these devices see the Wi-Fi network? Are you prompted to enter the password when they try to join the network?
Do you have MAC address access control enabled on the router?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 wifi trouble
SSID broadcast is enabled, security mode is WPA2-PSK, speed mode I tried them all, channel set to auto.
The devices see the network, I get prompted for the password, but they are unable to connect. The connect fine to the gues one though.
I don't have MAC address access control.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try switching the channel from auto to a fixed number.
Try using WPA-PSK or WPA-PSK+WPA2-PSK security.
If the password has special characters, then try a simpler password (i.e. alphanumeric).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestions! I tried all of them but I didn't manage to get it to work. My laptop connects fine to the 5GHz network but not to the 2.5GHz one. I copy/pasted the password so that cannot be an issue. My Mac just says there was a problem connecting, while my printer thinks it's a wrong password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset, especially if the problems started occurring after a firmware upgrade. Don't restore settings from a backup file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This worked. Thanks for the suggestion! It's a shame I had to do the configuration from scratch though.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
