Orbi WiFi 7 RBE973
Reply
R7000P Drops Packets
dbraun44
Follower
I am using the R7000P with Firmware V1.3.1.64_10.1.36. I have a Verizon FIOS connection to my router. I am periodically dropping packets which causes my VoIP phones to lose audio. My VoIP provider is telling me to disable IDS/IPS or Deep Packet Inspection. I have already disabled SIP ALG. Can anyone tell me how to disable Deep Packet Inspection? I do not see any setting for this. Or does anyone have any thoughts into why I am dropping packets?
Message 1 of 2
Guru
Re: R7000P Drops Packets
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
I would load up pingplotter.com app on a wired PC and connect it directly to the ONT. Run a test there to check for issues here.
Then put the R7000P online in the mix, and test with wifi on the router disabled and all other wired devices disconnected from the router.
I would probably factory reset the router and setup from scratch and do no enable Access Controls, Armor, Circle, QoS or Traffic Meter.
Run a pingplot test here and see what you find.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Is IPv6 enabled on the router? Something to try here as well.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 484 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
