Orbi WiFi 7 RBE973
Reply
R7000P Nighthawk time out continues to stop login
GEMALLTHETIME
I have 3 devices that displays 'LOGON TIME OUT, PLEASE TRY AGAIN. IF THIS ISSUE PERSISTS, TRY REBOOTING YOUR DEVICE'.  I have done that several times and it still will not work.  what iam I doing wrong?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 4
Guru
Re: R7000P Nighthawk time out continues to stop login
You're trying to login through the browser?
Have you tried a different browser?
What firmware are you on?
What modem/gateway are you connected to?
Message 2 of 4
GEMALLTHETIME
I'm trying to login through the NETGEAR app on my cell phone.  I also tried to login through my computer GOOGLE CHROME, and that don't work.  I can't update the firmware because I can't login.  I have a Iphone and a Samsung that it does the same on all the attempts I made. It worked when I first baught the router and I don't check it often but since the new firmware is available to download that is when I found it to not let me in my account. I'm haveing trouble with IP addresses being unsecure and differerent that what is suppose to be.  I don't understand most of this stuff.  So what do I do to rectify it?
Message 3 of 4
Guru
What modem/gateway to you have?
Have you factory reset the router and did a clean reinstall (not from backup)?
That'd get you back to the defaults.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 600 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
