- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000P drops internet in 5Ghz Mode - No response on Ticket Case #43907418
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm posting here for support as my offical ticket Case #43907418 is not getting any response on support even after detailed troubleshooting on call with agent.
THE ISSUE: R7000P - 5GHZ mode intermittently turns off and drops internet connectivity. This happens only in 5GHZ mode, 2.4GHZ runs fine so there is no issue with it dropping internet so my ISP is in the clear. After the issue occured consistently on the factory loaded firmware I have gone through the trouble of installing the latest firmware (1.3.2.126) and the issue still persists. I'm now suspecting a hardware issue - sad because the router is less than 6 months old!
Support not responding to my ticket Case #43907418 and me having to resort to posting on public forums is quite a sad state of affairs TBH.
Any help from the public at large is highly appreciated!! Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000P drops internet in 5Ghz Mode - No response on Ticket Case #43907418
which firmware version are you on?
What modem/gateway do you have?
what have you tried doing to fix the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- 1.3.2.126
- Direct ethernet cable with PPPoE with login details entered into router config
- Factory reset 4 times did not fix it. I have gone through the trouble of installing the latest firmware (1.3.2.126) and the issue still persists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try installing version 1.3.0.20 of the firmware over a hardwired connection, do a factory reset, a clean install (not from a backup), and then after reinstalling, disable auto updates. The newer versions got the netgear armor "upgrade". Maybe yours is one that doesnt play nicely with the armor firmware.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
