Orbi WiFi 7 RBE973
Reply
R7500v2 Slow Since V1.0.3.36
mrmagloo
Apprentice
I have Comcast 60mbps service and for the last month or so, I've been noticing only ~26mbps across ALL devices, wireless or gb wired.  At first I thought it was Comcast, and they did a bunch of tests, and found nothing. Then offered to come to the house, but anything past the modem would be at my expense.
So at that point, I figured I better do a PC direct to modem test, and sure enough, 68mbps. WTF??  I restored a recent backup from the last version I believe was V1.0.3.24 and no help.  I did a complete reset, then restore and still nothing.
Is there something that this new firmware is doing to affect throughput speed? Any, tips or fixes??
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 2
Accepted Solutions
mrmagloo
Apprentice
Re: R7500v2 Slow Since V1.0.3.36
Well, to help the next guy, I just found that v1.0.3.36 turns ON the QoS, - which seems to persist even through a Restore, and the second I saw that, I knew that was probably the issue.
The second I turned that garbage off, the speeds zoomed right back to 71mbps.
How irritating.
Message 2 of 2
All Replies
mrmagloo
Apprentice
How irritating.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1311 views
  • 2 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
