Orbi WiFi 7 RBE973
Reply
R7500v2 can’t connect to spectrum modem
Floridaburt
I had to move my spectrum modem / nighthawk WiFi router to another room in the house. The spectrum modem no longer recognizes the router.
Message 1 of 6
Guru
Re: R7500v2 can’t connect to spectrum modem
Doe the router recoginize the connection?
Does the modem work if you plug a computer/pc directly into it?
Does it work if you move it back?
Message 2 of 6
Floridaburt
I don’t have a way to connect my computer directly to the modem. When I first set this router up a spectrum technician somehow made the modem see the router. I just don’t know how he did that.
Message 3 of 6
Guru
Did you try moving it back?
maybe the coax connection isn't wired through to where you moved it to
Message 4 of 6
Floridaburt
If the coax cable wasn’t working wouldn’t the tv be non-functional?
Message 5 of 6
Guru
tv and cable boxes don't need as good of a signal as a modem does.
Which is why ISP's usually (or they should) put a double splitter on a cable when it first comes into the home. 1 leg should go to the modem and the other to feed the tv's/cable boxes.
without seeing your actual cable connections page, its tough to tell what your signal looks like where you moved it to.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 633 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
