RaviiXer20's avatar
RaviiXer20
Follower
Jul 02, 2017
R7800 Ethernet Amber Flashing
Just quick set up my new R7800. Everything is showing fine, I set it up also with my new DOCSIS 3.0 and all lights on it are green. However, on the router, it continues to indicate that it shows a connected Ethernet but blinks Amber like it pretends there's no Internet available. This is not the case and I can't get it to make the connection no matter how many times I power cycle to modem and router.
