- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7800 — Nighthawk X4S AC2600
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know, where i can fing the power adapter for the
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7800 — Nighthawk X4S AC2600
Online Amazon or fleabay? Just need same amp and volts (3.5A and 12v)
Same power adapter for the 7 series routers. R7000 would work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear does not sell replacement power adapters. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
Some generic adapters come with a set of tips that will fit a range of different devices.
These things are pretty common, so first check to see if you have something compatible lying around. But as @FURRYe38 says, try the usual suspects. Some will even list compatibility with various Netgear devices.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
