Rockmeister64
Aug 03, 2022Aspirant
R8000 5G modem drops connection when large files are copied
Hi
I have R8000 Triband router that has been working very well for years (except of the DNS issus for which I had to downgrade). I just bought a new Minisform UM560 which has a rz608 wifi 6e card (rebranded MediaTek MT7921K). Whenever I copy a large set of files from my NUC that hardwired to the router and the new pc the 5G modem stops responding. 2.4G modem is still active and working. I have to reboot the R8000 router for the 5G modems to start working again.
I am currently on the downgraded Firmware Version V1.0.4.68_10.1.75 due to the infamous DNS issue.
Any help is much appreciated.
Thanks
Rockmeister64
have you tried copying the large files between other devices?
6E is pretty new and maybe there's an issue with that specific card/device.
- Rockmeister64Aspirant
I should have mentioned it in my original post. I have copied the same set of large files between the same NUC and an older laptop using the exact same 5g Modem and had no issues.
Thanks
Rockmeister64
If it only happens when connected to the new device, it kind of points at that new device as the issue.
Got a spare usb wifi adapter around you could try it with on that device to see if its related to the card or the windows install?
