Orbi WiFi 7 RBE973
Reply
R8000 Nighthawk X6 AC3200 only gets half internet speed
MongooZ
Hello guys,
So here i come with my weird issue. My router simply drops half bandwith (download only) after 24 hours. Let me explain. My ips bumped my bandwith to 200mbps/30mbps from 100/20. After running several speed tests, i only got 100 / 30. Reseted modem and router, finnally got 200/30 but the next day back at 100/30... Even with modem/router reset couldn't get the bandwith back to normal. So i decided to roll back firmware version to initial and see what i get. Take a look at those shots taken yesterday evening after the firmware rollback:
Thought i fixed my issue ! But this evening... after coming back from work...
No matter on many time i run the speed test, same thing... Even through speedtest.net. Can't get my bandwith back. If i reset the modem and connect directly to it tho, i get full bandwith !
Let me give you some details on my router settings:
Firmware: 1.0.0.46 (upgrading it back in a moment tho as the problem remains)
Turned off WMM: Forgot to specify - This fixed the issue the first time a week ago !
MTU = 1500 (tried 1300 - 1400 - 1450 unsuccessully)
Internet port statistics:
Anyone having an idea?
Thank you very much guys !
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 7
Accepted Solutions
Retired_Member
Not applicable
Re: R8000 Nighthawk X6 AC3200 only gets half internet speed
replace the cable between modem and router WAN port SHOULD connect @ 1000m
make no mistake WMM needs to be enabled For WIFI
Message 2 of 7
All Replies
Retired_Member
Not applicable
Message 2 of 7
MongooZ
Hello searay !
Thank you for your suggestion ! Before buying a new cable, which i will tomorrow, may i ask why you think this should fix my problem?
thank you
Message 3 of 7
Retired_Member
Not applicable
the wan port must connect @ 1000m your previous post shows it at 100m    either bad modem, bad cable, bad router or bad firmware but you already changed FW
Message 4 of 7
MongooZ
Correct ! Then i'll grab new set of cables tomorrow and give it a try; i'll keep you updated.
Thank you very much searay
Message 5 of 7
MongooZ
Thank you very much searay, problem fixed by replacing cable from modem to router !
Message 6 of 7
Retired_Member
Not applicable
Great News!
You're welcome
Message 7 of 7
Discussion stats
  • 6 replies
  • 4252 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
