Orbi WiFi 7 RBE973
Reply
R8000 Update stuck and will not boot back up after latest firmware upgrade.
Not applicable
I did a firmware upgrade last night and now the system can't connect. All the lights were on like it was working and nothing was working.
After 2 hours I rebooted. Now the system just cycles. All lights then it looks like it tries to boot because I get an occasional ping response but then it reboots.
I tried doing a factory reset and nothing. Any ideas??
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 9
Accepted Solutions
Guru
Re: R8000 Update stuck and will not boot back up after latest firmware upgrade.
try the nmrpflash then
Message 4 of 9
All Replies
Guru
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 9
Not applicable
The tftp isn't working because the R8000 is cycling. I tried running a ping in a separate cmd window so I could time the tftp as soon as I see it reply but it stops replying before the transfer finishes and I get a "Connect request failed"
Message 3 of 9
Guru
Message 4 of 9
Not applicable
I can't get nmrpflash to work on my Mac. I downloaded nmrpflash-master.zip extracted it and there is no nmrpflash in the directory to sudo run?
Message 5 of 9
Not applicable
I I downloaded the NPcap and installed to get rid of the missing dll error. The nmrpflash -L only displays my eth and wifi mac addresses. The ping response isn't long enough for me to get the net# for the router?
Message 6 of 9
Guru
You don't need a net# for the router. did you scroll down and read through how to use it?
Message 7 of 9
Not applicable
Sorry I miss understood. I followed the instructions and received an error "Timeout while waiting". I had the router off, started the nmrpflash and immediately turn it on when the waiting for connection appeared. Image file attached of error.
Message 8 of 9
Not applicable
I tried a couple of more times and it finally took. Thanks for helping out with resolving this!!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1907 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
