nadeen
May 01, 2021Follower
R8000 incorrect password for wifi, 2.4gHz channel not recognized
Hello - My router was reset last week and since then it hasn't been working correctly.
1- Only 5gHz channel 2 allows login, other channel says password incorrect even tho it matches router config
2 - My 2.4gHz channel isn't visable at all
3 - My stupid printer doesn't detect any of my wifi networks
I updated the firmware when the router reset to 1.0.4.68_10.1.75.
I have tried
1- disabling smart connect (was already disabled)
2 - setting password to 12 characters, resetting password multiple times
3 - disabling QoS (was already disabled)
4 - changing channels to 44 and 149
I am reluctant to do a hard reset or restore because I do have at least 1 channel working and what if that stops working?? I do have an ethernet connection to the router.
Any help is appreciated.
Thank you.
No RepliesBe the first to reply
