Orbi WiFi 7 RBE973
Reply
R8000 - no lights, only powers is blinking
Npowers804
Follower
Only light is the power light and it’s blinking. I connected a computer to the hard wire and it work so I know I have internet there. But It doesn’t seem like the router has any internet. I have tried a restart but when I try to add it back it says I need to connect to the device WiFi, but it doesn’t show up and can’t connect manually. Any help is needed. I haven’t updated the firmware in a while. But now I don’t know how to do it since it won’t connect to the internet.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
antinode
Guru
Re: R8000 - no lights, only powers is blinking
> Only light is the power light and it's blinking. [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] I connected a computer to the hard wire and it work so I know I
> have internet there. [...]
   No, you don't know that.  A functioning Ethernet cable and Internet
connectivity are two different things.
> [...] But It doesn't seem like the router has any internet. [...]
   Perhaps because the router's firmware is corrupt.
> [...] I have tried a restart [...]
   Restart or reset?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions, "Troubleshoot", and "Reset".
> [...] when I try to add it back it says I need to connect to the
> device WiFi, [...]
   I don't know what "add it back" means to you, or what, exactly, says
what, exactly, when you do what, exactly.
   Interesting: What, exactly, are you doing?  What, exactly, happens
when you do it?
   Much less interesting: What you think it all means.
Message 2 of 3
wcalifas
Prodigy
the firmware might have been corrupted. Did you try resetting it by pressing the reset button with a paper clip for 30 seconds. You might be able to reload firmware using tftp, give that a try.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 790 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
