- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R900 Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
R900 Issue
I have R900 router. Modem is single port in DHCP ( Charter ). If I feed Netgear (dumb/unmanaged) switch first which then feeds the router and my pc, the router will never go online. If I leave in the same configuration but remove PC from switch then reboot router it works fine. If I then add pc back to the switch the pc will not pull an IP address. This only happens with THIS router.
If I put the router first and then feed switch I can plug my PC into the switch or router and of course I get online. This setup does not work for me as the location of the router doesnt provide a good wifi signal.
In short, the router does not like to share a switch with my PC and I cannot figure out why. Its either one or the other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R900 Issue
R9000 router? R900 isn't a valid model?
What is brand and model of this switch your using?
What is the brand and model # of the ISP modem?
Be sure that you are configuring the switch in the following connection configuration:
ISP modem>Router>Switch<PC and wired devices connected to the switch.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R900 Issue
Your isp only supplies 1 public ip address. Its then on whatever it supplies that public ip address to to supply private ip addresses to your devices. Your switch can't supply them as its a simple unmanaged switch. Which is why you need to go modem--->router--->switch/devices.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R900 Issue
As @plemans says, your proposed layout simply will not work.
You need to plug the router into the modem. If you cannot run a long cable, there is a possible alternative.
Powerline Ethernet is a "dumb" approach to networking. It uses the mains circuit as bit of wire, with no network manage or anything that depends on IP addresses involved. It could provide an Ethernet link between the modem and the router. Put the switch after that.
Netgear doesn't market Powerline for this purpose, but I have seen reports here that it works.
The quality will depend on the local mains wiring and perhaps the speed of your Internet service. I use Powerline to connect an access point to the router with no apparent ill effects, but that is a DSL connection, much slower than Powerline can handle.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P• What is the difference between WiFi 6 and WiFi 7?
