- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R9000 — Nighthawk X10 AD7200 transmitting 5ghz but not accepting connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have a R9000 — Nighthawk X10 AD7200 Smart WiFi Router. The router is transmitting a 5GHz signal but not accepting any connections to it.
So far I have tried:
- Installed dd-wrt
- Issue persists
- flashed back to newest NETGEAR firmware via tftp
- Issue persists
- Factory reset
- Issues persists
- Tried various older versions of firmware
- Issue persists
- Disabling security
- Issue persists
- Changing channels
- Issue persists
As of 20220605 the router is on the newest version of NETGEAR firmware V1.0.5.40. 2.4Ghz is working and hardwired connections are working as expected.
Are there any other options I can try? I am at a loss as to why it started happening...
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R9000 — Nighthawk X10 AD7200 transmitting 5ghz but not accepting connections
What happens if you disable WPA security on the 5Ghz radio, then does anything get connected? Set WPA2 and AES after testing this.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38
The modem is a Netgear C7000. I attempted to disable security and connect; I am still unable to do so. I also changed the security option and changed the password, same result. I presume it must be a hardware issue at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is the C series modem in? Bridge?
What browser are you using? Try MS Edge or Firefox. Factory reset the router and setup from scratch. Use the configure router yourself option.
Disable Smart Connect.
Disable WPA security...can you set this here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the C7000 is a modem/router combo, I have the router mode disabled on it. It is functioning solely as a modem at this point.
To answer your browser question, I typically use Google Chrome to manage and maintain any router settings and configuration. Does Edge or Firefox offer me something Chrome does not?
Smart connect has always been disabled as it is a feature I do not like. I have done what you have suggested to no avail. After setting up from scratch, I can see the 5ghz channel in my available networks but am unable to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd give Voxel's 3rd party FW a try and see if this changes anything. If it doesn't then I would presume there is a HW failure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Sorry it didn't work out.
If the router is working otherwise, you could just disable the WiFi radios on the router and install a external wired Wireless AP or WiFI MESH system in AP mode to work with the R9000 router.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
