- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 and FireTV Can't Connect, Internet on PCs works
- Mark as New
- Bookmark
- Subscribe
- Permalink
All other internet connections in our home work except for our FireTV sticks. I have one FireTV stick that will connect to the WiFi but shows no internet. (They all started this way.) I decided to reset another FireTV stick to factory settings and now it won't connect to our WiFi when going through the setup process. The message displayed is "Cannot contact Amazon.com".
I updated the firmware on the RAX120 to v1.2.2.24.
I've shutoff and rebooted the router and the FireTV numerous times.
I've confirmed with our internet provider that our internet signal to the house is good and working as intended.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please visir and post about this over in the RAX WiFi 6 forum:
Good Luck.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 and FireTV Can't Connect, Internet on PCs works
I just de-registered all FireTVs. I went through the factory reset process using my phone's hotspot. The FireTV stick then went through an update process and completed the setup, including registration. I then turned off my hotspot and was able to connect to my WiFi.
Seems as if the FireTV sticks needed an update... wish it would do it without all of this nonsense.
Thanks for the help @FURRYe38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contact Amazon regarding there product.
Good Luck.
