Orbi WiFi 7 RBE973
Reply
RAX75 unable to access router settings using my iOS devises. But will work on brothers android phone
Benjamin123
Hello all, thank you in advance for your help.
I’ve been trying for DAYS to access my router settings via my iPhone 12 or iPad Pro (while connected to my wifi network of course) with no luck. Those are the only devises I currently have. No laptop or desktop. When I try, I get “safari cannot open the page because it could not connect to the server”. Here is what I have tried so far:
-Using my 2.4g and 5G connection
-Connecting my iPad via ethernet directly to the router
-power cycling all devises(iPad, iPhone, router, modem)
-factory resetting my router.
-typing in my router ip(192.168.1.1) into the browser search. I have verified that is my routers ip.
-typing in www.routerlogin.net and routerlogin.com
-using other web browsers(safari, Firefox, chrome)
The only way I’ve been able to access my router settings is through my brothers android one+ phone. It connects no problem and the admin login page pops right up. Does anyone know why I’m unable to assess the login using my iOS devises?
Your help is much appreciated!!!
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Guru
Re: RAX75 unable to access router settings using my iOS devises. But will work on brothers android p
Most mobile phone access to routers is done thru the Nighyhawk app.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 4
Benjamin123
Ok thanks for the heads up, really appreciated it. I’ll repost it there as well.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 749 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
