Orbi WiFi 7 RBE973
Reply
RBK852 parent control
PhilRoberts
Does anyone have a date or any update on when parent control will be added to the RBK852
Message 1 of 3
Guru
Re: RBK852 parent control
Netgear has set up a community forum specifically for the SPC product. Most of the people who watch that forum are more likely to have experience with SPC and know how to work it better than those of us who follow this "Nighthawk Router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
https://www.netgear.com/home/services/smart-parental-controls/
Also,
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck
Message 2 of 3
This will probably depend on new firmware for the RBK852.
SAs @FURRYe38 says, the best place to keep an eye on that front might be the section where they know about the RBK852.
That's probably here:
Orbi (AX) - NETGEAR Communities
But you could also see if they are talking ab out it here:
Mesh WiFi Systems - NETGEAR Communities
Netgear's community is hard to navigate but you won't find many people who know about that stuff in a section on Nighthawk WiFi Routers.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 643 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
