- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Random Loss of Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an #R8500 that's worked fine for several years. Suddenly it's apparently losing the Internet connection. The WiFi light (rightmost) on the router is on, but the other two are off when in normal operation all three are on. If I unplug, wait, and plug it in again it restores the Internet. I use this for smarthome control while away and I can't keep losing the connection when I'm not around to unplug/plug the router. Any ideas besides getting a new one (of another brand?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Random Loss of Internet
What other LEDS are off? Power or Internet?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I've tried (and what I'm waiting to see if it helped) is to re-nenable the router getting the DNS address from the ISP. I was using a static DNS address. I'm wondering if that had some impact because I'd changed the setting a couple months ago. So far, since I've gone back to using the ISP DNS (and setting my preferred DNS on my computer) it's not failed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Possible odd problem with the static DNS you had been using before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not likely; that's the DNS I've had set in my computer settings all along. I wonder if it has something to do with how a lease is renewed on the ISP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything is possible. Go with what works.
Enjoy. 😉
