Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyShare will not stream. States, "Downloading not supported at this time." Please advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-11-04
05:28 PM
2020-11-04
05:28 PM
I just purchased a NightHawk AX5200. I previously had a cable-modem/router combo. The ReadyShare on the combo unit worked fine; however, on the AX5200 the ReadyShare will not stream the movies I have hooked up to the USB port. I can see all of the files but when I select on I get a reading, "Downloading not supported at this time." I've reset the router but still no luck. Please advise.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-11-04
06:25 PM
2020-11-04
06:25 PM
Re: ReadyShare will not stream. States, "Downloading not supported at this time." Please
Not sure what modem/router combo device you had before but it potentially had a dlna server built into it. Many of netgears routers had that for a while. i haven't seen dlna built into any of the newer AX routers. And support was even pulled from some of the older AC routers to add in netgear armor.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
