Orbi WiFi 7 RBE973
Reply
Reconnecting Netgear ex3110 to wifi
Monty81
Follower
I have a Netgear EX3110 which I use to connect a Fetch box in my bedroom to the internet.  It was working fine until I had to get a new router.  Now I cannot get it to connect and I have forgotten what to do.  I have managed to get the power light to go to green and also the device light is green.  Pressing and holding the WPS button results in it blinking green for a while then going off.  I am not asked to enter the password for the new wifi.  Can anybody help please????
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 3
BlueMntnG
Re: Reconnecting Netgear ex3110 to wifi
Hi, I'm by no means an expert but perhaps you need to point it to the IP address of the router ?  Or could it be an IP address conflict between the two routers.  I am not sure and wouldnt be able to guide you through this although I recently had an IP address conflict issue between a nighthawk extender and the main router.
It's difficult when you change things.
Best of british !!
Cheers,
Message 2 of 3
Factory reset the EX3110 and set it up from scratch. You need to get it to forget the link with the previous router.
Visit the support pages:
Support | NETGEAR
Begin with the Quick Start/Installation Guide.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 684 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
