Orbi WiFi 7 RBE973
Reply
Removing dd-wrt firmware and restoring to factory condition
Herbert323
Hi, I have a Nighthawk R8000 which I bought with DD-Wrt firmware installed. I would like to remove that firmware and restore to a factory configuration. I might have messed things up. I selected the Factory Restore option, it downloaded some firmware and rebooted. Now, I can't access the router at all. It is attached to a Cable Modem provided by my internet provider and I have found it with an IP but when I try to access it no luck.
Any suggestions?
Message 1 of 3
Accepted Solutions
Herbert323
Re: Removing dd-wrt firmware and restoring to factory condition
Thanks my friend, that worked.
Herbert
Message 3 of 3
All Replies
JamesGL
Master
Hi @Herbert323,
If you want to use the official firmware for R8000, you may download it on the link below.
http://kb.netgear.com/app/answers/detail/a_id/30010
For loading the firmware via TFTP since the router is unaccessible, you may check this article.
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the...
JamesGL
Community Team
Message 2 of 3
Herbert323
Herbert
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 115284 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
