Orbi WiFi 7 RBE973
Reply
Restore R67000v3 with WNDR3700v3 backup?
agent86
Star
Hello,
I am replacing a Netgear WNDR3700v3 router with a Nighthawk R6700v3 router. It would be an incredible time saver, if I could simply backup my WNDR3700v3 settings and restore the config file on the R6700v3 router.
Can the configuration settings from an older Netgear router be migrated to a newer Netgear router, specifidcally from the WNDR3700v3 to the R6700v3 using the backup/restore feature on the routers?
Thank you,
agent86.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
microchip8
Master
Re: Restore R67000v3 with WNDR3700v3 backup?
No, they're vastly different routers running incompatible firmware
Message 2 of 2
All Replies
microchip8
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 768 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
